BMA400 tap interrupt does not appear in interrupt status register
Hi!
So far I have successfully rewritten my code to use the BMA400. I am using the I2C interface and both interrupt lines.
On INT1 the single tap and orientation interrupts are active.
On INT2 the data ready interrupt is active.
On INT1 line I get proper signals to signal the interrupt. When I read the status register (0x03) it shows 0x95 meaning there is an interrupt active.
When reading the interrupt status registers (0x0E, 0x0X,0x10) I only get proper reading for the orientation interrupt (0x02,0x00,0x00). When a tap occurs it signals the interrupt, but there is no bit active in any of the interrupt status registers. I would expect (0x00,0x04,0x00) for single tap but am getting only zeros.
I confirmed that the I2C interface works well for single byte read and multi byte read.
Is there something in my setup that is wrong?
    accError += BMA400_WriteRegister( BMA400_REG_ACCEL_CONFIG_0, BMA400_MODE_NORMAL );
    // BMA400 needs approx 1500us to switch from sleep to normal mode
    usleep(1500);
    //---- CONFIG1 ----
    // OSR = 00, BMA400_ACCEL_OSR_SETTING_0
    // ODR = 200 Hz, BMA400_ODR_200HZ
    // BMA400_RANGE_2G
    //---- CONFIG2 ----
    // src data reg = BMA400_DATA_SRC_ACCEL_FILT_1 (variable ODR)
    values[0] = (BMA400_ODR_200HZ                                    ) | \
                (BMA400_ACCEL_OSR_SETTING_0 << BMA400_OSR_POS        ) | \
                (BMA400_RANGE_2G            << BMA400_ACCEL_RANGE_POS);
    values[1] = (BMA400_DATA_SRC_ACCEL_FILT_LP << BMA400_DATA_FILTER_POS);      //todo debug code??
    accError += BMA400_BurstWrite( BMA400_REG_ACCEL_CONFIG_1, values, 2 );
    CC_LOGD("REG_ACCEL_CONF          (%u) 0x%02x 0x%02x 0x%02x", BMA400_BurstRead( BMA400_REG_ACCEL_CONFIG_0, values, 3), values[0], values[1], values[2] );
    //--- tap config ----
    values[0] = (BMA400_TAP_X_AXIS_EN       << BMA400_TAP_AXES_EN_POS) | \
                (BMA400_TAP_SENSITIVITY_3                              );
    values[1] = 0x06;
    accError += BMA400_BurstWrite( BMA400_REG_TAP_CONFIG, values, 2 );
    CC_LOGD("REG_TAP_CONFIG          (%u) 0x%02x 0x%02x", BMA400_BurstRead( BMA400_REG_TAP_CONFIG, values, 2), values[0], values[1], values[2] );
    //---- tilt config ----
    values[0] = 0xC0 | 0x10 | 0x0C ;    // z/y-axis, src=LP-filtered, auto-update from LP-filtered
    values[1] = 0x06;                   // orient threshold, LSB = 8 mg
    values[2] = 0x00;                   // stability threshold - unused
    values[3] = 0x32;                   // duration until int, multiple of src ticks (filt_LP = 100Hz => 10ms)
    accError += BMA400_BurstWrite( BMA400_REG_ORIENTCH_INT_CONFIG, values, 4);
    CC_LOGD("REG_ORIENTCH_INT_CONFIG (%u) 0x%02x 0x%02x 0x%02x 0x%02x", BMA400_BurstRead( BMA400_REG_ORIENTCH_INT_CONFIG, values, 4), values[0], values[1], values[2], values[3] );
    //---- FIFO config BMA400_REG_FIFO_CONFIG_0 ----
    values[0] = BMA400_FIFO_EN_XYZ << BMA400_FIFO_AXES_EN_POS;  // x/y/z-axis enabled, streaming mode, no-flush, 12bit-mode
    values[1] = 0x00;                   // FIFO watermark = 0
    values[2] = 0x00;                   // FIFO watermark = 0
    values[3] = 0x00;                   // FIFO read enabled
    accError += BMA400_BurstWrite( BMA400_REG_FIFO_CONFIG_0, values, 4);
    CC_LOGD("REG_FIFO_CONFIG         (%u) 0x%02x 0x%02x 0x%02x 0x%02x", BMA400_BurstRead( BMA400_REG_FIFO_CONFIG_0, values, 4), values[0], values[1], values[2], values[3] );
    //---- interrupt config ----
    //disable all interrupts before configuring them
    //read them
    CC_LOGD("REG_INT_CONF (before)   (%u) 0x%02x 0x%02x 0x%02x 0x%02x 0x%02x 0x%02x", BMA400_BurstRead( BMA400_REG_INT_CONF_0, values, 6), values[0], values[1], values[2], values[3], values[4] );
    values[0] = BMA400_EN_ORIENT_CH_MSK | BMA400_EN_DRDY_MSK;// INT_CONF_0: enable orientation change and data-ready
    values[1] = BMA400_EN_S_TAP_MSK;    // INT_CONF_1: enable S-Tap
    values[2] = BMA400_EN_ORIENT_CH_MSK;// INT1_MAP  : map orientation to Int1
    values[3] = BMA400_EN_DRDY_MSK;     // INT2_MAP  : map data-ready to Int2
    values[4] = BMA400_EN_S_TAP_MSK;    // INT12_MAP : map S-Tap to Int1
    values[5] = 0x00;                   // INT12_IO_CTRL: push-pull, low-active
    accError += BMA400_BurstWrite( BMA400_REG_INT_CONF_0, values, 6);
    CC_LOGD("REG_INT_CONF            (%u) 0x%02x 0x%02x 0x%02x 0x%02x 0x%02x 0x%02x", BMA400_BurstRead( BMA400_REG_INT_CONF_0, values, 6), values[0], values[1], values[2], values[3], values[4], values[5] );
    // check status of device after config
    BMA400_ReadRegister( BMA400_REG_STATUS, &value);
    CC_LOGD("Status: %u", value);
Also is there something I am missing about interrupt behaviour of tap/double tap interrupt maybe?
I read the document: "How to generate BMA400 single-tap and double-tap interrupt.pdf" and found the notice:
"The single-tap interrupt will be cleared automatically when the above conditions [sope and timing] are no longer valid."
This does not mean that the interrupt flags in the interrupt status are cleared, correct?
Thanks for any pointers!
Cheers
JR
