I am working with the BMA423 accelerometer and trying to use the step counter feature.I was able to get the chip id and have verified the chip by running the self test.I am using the driver from github and doing the following to enable and get output of the step counter feature.
rslt |= bma4_set_accel_enable(BMA4_ENABLE, &dev);
rslt |=bma4_set_accel_config(&accel_conf, &dev);
rslt |= bma423_feature_enable(BMA423_STEP_CNTR,BMA4_ENABLE,&dev);
rslt |= bma423_reset_step_counter(&dev);
rslt |= bma423_step_counter_output(&step_count , &dev);
The step counter output for the first time is 00 which is correct.After this, I am trying to get the step counter output in a loop while moving the accelerometer.I get random values out of the Step_counter registers.I am not sure why. Is there anything that looks incorrect for using the step counter feature?
Thank you.
