I'm opening this thread because I made a custom board with a BMA456 sensor, but it's not working. If I try to read the 0x00 register I don't get the 0x16 as result. I also tried to connect my board to arduino and run one of the examples but they also don't work. The other I2C sensors are all working. I tried both 0x18 and 0x19 as device address. I also tried to use the online API for this sensor, and I get "bma456_read_int_status.Error [65532] : Null pointer"
Did I do any error in the schematic that prevents the sensor from working? If yes, is it possible to fix it somehow without printing a new PCB?
If the schematic is correct, what can it be the issue?
Thank you all in advance,
Best regards
