The datasheet shows config file load as part of the device init sequence (section 4.2). I assume that applications like tap detection require the config file, but is a config file required if the data only needs to be sampled (e.g., 50 Hz ODR using the DRDY interrupt)? If not, how should the device init sequence be modified?
BMA456: operation without config file load
- Sensor
- BMA456
- Application
- Wearables
- Development Platform
- custom
- Project Phase
- Evaluation
- Label
- Software
BMA456
