BMA456 Soft Reset Error
I am running into an issue where issuing the SoftReset command (via the `bma4_soft_reset()` function that is part of the API) to the BMA456 device fails at a fairly high rate. Looking at the I2C bus with a logic analyzer it appears that for some reason the BMA456 is not ACKing the command.
I found this posting that describes similar behavior but for a different device. /mems-sensors-forum-jrmujtaw/post/bmi088-soft-reset-failure-NLONx65SuHbHtSj. Does the BMA456 have the same known issue?
