BME280 and BME680 humidity accuracy
I have a design where I can plug either BME280 or BME680. I am using BME280 driver version 3.4.2 and BSEC driver (full one not lite) version 3.5.10 for BME680 driver and version 1.4.7.4 for BSEC. Software is running on ESP8266. I am using float calculation for both.
I am seeing differences in humidity measured by BME280 and BME680 (and temperature also)
I have tested different devices and here what I see:
Same board, same place, same time, just replaced the sensor:
DevicesHumidityTempBME280 dev159.7%25.9BME680 dev174,5%22.8BME680 dev2
73,4%
22.9
Two different boards, same place, same time:
DevicesHumidityTempBME280 dev254,6%24,0BME680 dev372,3%19.9
Could it be that the humidity offset is linked to the temperature offset? And if not what could be the cause of this offset
Normally I am adding an offset to temperature after measurement so that sensors indicate right and same temperature. But I just realize that there is an offset between these 2 type of devices for temperature.
Pressure measurement are almost identical between type of devices.
I have also tried integer calculation (both 32b and 64b)  on BME280 but the measurements where the same as when using float.
Any idea where I could look for?
NB: I don't have a reference for humidity so I don't know which sensor is right, even I would think that BME680 is closer to real value.
