Hi there!
To verify that my integration is correct, I used the BSEC configuration "generic_33v_3s_4d" and the sampling rate BSEC_SAMPLE_RATE_LP (one sample every 3 seconds).
The BSEC library wakes up every 3 seconds to take a BME680 reading and report the calculated values (IAQ, eCO2, VOC, ...). The whole operation takes a whopping 281 ms out of 3000 ms and that will kill the battery in no time 😞
I then proceeded to use the BSEC configuration "generic_33v_300s_4d" and the sampling rate BSEC_SAMPLE_RATE_ULP (one sample every 300 seconds).
The BSEC library still wants to wake up every 3 seconds, but only wastes 3 ms each time. Every 300 seconds it takes a reading and reports calculated values. This operation takes 2031 ms, not 281 ms. This is still bad if the application is supposed to last for years.
Why does the BSEC library want to wake up every 3 seconds? Can I safely ignore and only call it once every 300 seconds?
Are there BSEC library settings to improve battery life, i.e. sleep for a long time, wake up to take a measurement and perform a calculation quickly and then go back to sleep?
Why must the time stamps be in 64-bit nanosecond resolution? It feels like overkill and a waste to me on a 32-bit architecture. Why would a 32-bit millisecond time stamps not suffice?
Thanks in advance,
Pieter
