BME680: BSEC warning code: 100
I have tried to use two BME680 at ESP32 for compare the values for two identical sensors.
Using for each BME a seperate I2C bus.
If I try the BME680_basic_data_logging sample all is working fine, I get values from both sensors.
Using the BME680_config_state sample I will get for the second sensor the iaqSensor.status value "100" back.
Didn't found it in documentation / source code - what does this mean?
As explanation - I use an array for the sensors - maybe the bsec lib have any problems here with it?
Bsec iaqSensor[2];
iaqSensor[0].begin(BME680_I2C_ADDR_PRIMARY, I2Cone);
iaqSensor[1].begin(BME680_I2C_ADDR_PRIMARY, I2Ctwo);
void loop(void)
if (iaqSensor[0].run()) {
if (iaqSensor[1].run()) {
of course modified the functions:
checkIaqSensorStatus(int n)
updateState(int n)
loadState(int n)
So two questions:
- what does mean the errorcode 100
- is it possible to use the bsce lib with two sensors in one sketch?
Thanks!
Michael
EDIT: In the meantime I have seen that it seems not to be possible without major changes in lib to use 2 sensors with this samples.
