BME680 Gas Reading Speed
Hi.
- What is the fastest update rate for each of the 4 parameters (gas, temp, humidity, pressure) when using the BSEC and the BME680?
- When NOT using the BSEC, what is the fastest update rate for the 4 sensors?
- Can this update rate be sustained for long periods if power were not an issue. Page 24 of the datasheet seem to suggest that it is not sustainable (under Continuous).
Thanks,
Kevin
