Hi everyone,
I am currently trying to use the BME680 gas sensor to measure air resistance. After reading through the sensor datasheet I saw that one can configure the heater plate temperature and duration for gas sensing. Is the proper selection of these parameters required to receive accurate gas readings? What is the standard configuration of these parameters? Is the standard configuration the best to use?
Thanks!
