Am trying to implement BSEC on an ESP32 module, using ESP-IDF and the example descriped in BSEC Integration guide BST-BME680-Integration-Guide-AN008-47.pdf
While the example run correctly using Arduino IDE and IAQ value and accuracy showup on log after 300 seconds, with startup values at 25.0
[186120.00] T: 28.51| rH: 45.03| IAQ: 25.00 (0)| Static IAQ: 25.00| CO2e: 0.00| bVOC: 0.00
[660120.00] T: 28.50| rH: 47.44| IAQ: 56.14 (1)| Static IAQ: 38.60| CO2e: 0.00| bVOC: 0.00
the same basic example using ESP_IDF (except the output function and i2c related fonctions) with start at 0.00
and maintain that value after 300 seconds
[3261.72] T:28.46 | rH:46.44 | IAQ:0.00 | IAQ_acc:0 | Static IAQ:0.00 | Raw gas :0.00 | Status : 0
No problem with temperature and humidity though ...
What i noticied is that in file bsec_integration.c is that the code with ESP-IDF seems to ignore
case BSEC_OUTPUT_IAQ
case BSEC_OUTPUT_STATIC_IAQ
those outputs are never triggered
It's not the case when compiling with Arduino, and am using exactly the same .c .h .a files.
Thanks
