Hi. I am planning to use BME680 in my project but have some questions. I already downloaded sample code for BSEC and bme680 api and looked through it. But I dont understand why I must use BSEC. Is it important to use BSEC and also *.lib file for my platform or I can use only functions from bme680.c? When I compile my project in Keil MDK5 it gives a lot of errors L6406E: No space in execution regions with .ANY selector matching .....because I use in this project E-Ink display and nrf24l01.
Also I have problem in communicating with sensor. I already filled bus_write and bus_read functions:
int8_t bus_write(uint8_t dev_addr, uint8_t reg_addr, uint8_t *reg_data_ptr, uint16_t data_len)
uint16_t i;
int8_t rslt = 0; /* Return 0 for Success, non-zero for failure */
* Data on the bus should be like
* | I2C action | Data |
* | Start | - |
* | Write | (reg_addr) |
* | Write | (reg_data[0]) |
* | Write | (....) |
* | Write | (reg_data[len - 1]) |
* | Stop | - |
I2C_AcknowledgeConfig(I2C_PORT,ENABLE); // Enable I2C acknowledgment
I2C_GenerateSTART(I2C_PORT,ENABLE);
while (!I2C_CheckEvent(I2C_PORT,I2C_EVENT_MASTER_MODE_SELECT)){}; // Wait for EV5
UART1_Transmit_string("\r\nStart sent");
I2C_Send7bitAddress(I2C_PORT,dev_addr,I2C_Direction_Transmitter); // Send slave address
UART1_Transmit_string("\r\nDev_addr sent");
while (!I2C_CheckEvent(I2C_PORT,I2C_EVENT_MASTER_TRANSMITTER_MODE_SELECTED)){}; // Wait for EV6
I2C_SendData(I2C_PORT,reg_addr); // Send register address
UART1_Transmit_string("\r\nReg_addr sent");
while (!I2C_CheckEvent(I2C_PORT,I2C_EVENT_MASTER_BYTE_TRANSMITTED)){}; // Wait for EV8
for(i=0; i < data_len; i++)
I2C_SendData(I2C_PORT, reg_data_ptr[i]); // Send all bytes
I2C_GenerateSTOP(I2C_PORT,ENABLE);
return rslt;
int8_t bus_read(uint8_t dev_addr, uint8_t reg_addr, uint8_t *reg_data_ptr, uint16_t data_len)
uint16_t i =0;
uint8_t status = 0;
while (!I2C_CheckEvent(I2C_PORT,I2C_EVENT_MASTER_MODE_SELECT)); // Wait for EV5
I2C_Send7bitAddress(I2C_PORT,dev_addr,I2C_Direction_Transmitter); // Send slave address 0x76
while (!I2C_CheckEvent(I2C_PORT,I2C_EVENT_MASTER_TRANSMITTER_MODE_SELECTED)); // Wait for EV6
while (!I2C_CheckEvent(I2C_PORT,I2C_EVENT_MASTER_BYTE_TRANSMITTED)); // Wait for EV8
I2C_GenerateSTOP(I2C_PORT,ENABLE); // Send STOP condition
delay_ms_sys(1);
I2C_GenerateSTART(I2C_PORT,ENABLE); // Send repeated START condition (aka Re-START)
I2C_Send7bitAddress(I2C_PORT,dev_addr,I2C_Direction_Receiver); // Send slave address for READ
while (!I2C_CheckEvent(I2C_PORT,I2C_EVENT_MASTER_RECEIVER_MODE_SELECTED)); // Wait for EV6
while (!I2C_CheckEvent(I2C_PORT,I2C_EVENT_MASTER_BYTE_RECEIVED)); // Wait for EV7 (Byte received from slave)
status = I2C_CheckEvent(I2C_PORT, I2C_EVENT_MASTER_BYTE_RECEIVED);
//status = I2C_CheckEvent(I2C_PORT, I2C_EVENT_MASTER_TRANSMITTER_MODE_SELECTED);
reg_data_ptr[i] = I2C_ReceiveData(I2C_PORT); // Receive high byte
if(status == 1)return 0;
else return status;
but sensor did not answering(I checked it with logic analyzer). It stops after slave address sent(0x76).
