bme688 bsec library problem
Hi ,
I am getting the below results in my work location using bme688 sensor with bsec library. After 1 hours the library is getting crashed. I removed while loop in bsec_iot_loop() function.
With this case your library and our program is running 1 hour.
Beginning when fresh start results
IAQ :25.00
IAQ_accuracy : 0
Temperature(C) : 26.45
Humidity(%) : 45.45
Pressure(hPa) : 939.43
Temperature_raw(C) : 26.56
Humidity_raw(%) : 45.15
GAS : 12917167
IAQ_static : 25.00
CO2_eq : 500.00
Breath_VOC_eq : 0.50
After 40-50 minutes results
IAQ :210.38
IAQ_accuracy : 3
Temperature(C) : 26.37
Humidity(%) : 42.45
Pressure(hPa) : 942.31
Temperature_raw(C) : 26.48
Humidity_raw(%) : 42.23
GAS : 12917167
IAQ_static : 174.37
CO2_eq : 1743.74
Breath_VOC_eq : 4.78
After 60 minutes results
Library crashed or not calling your function (bsec_iot_loop)? why?
But after 1 hour the device is getting crashed or not calling the bsec function (bsec_iot_loop). But still I am calling the function in our timer other functions are executing. But your API (bsec_iot_loop) is not calling why is there anything I need to refresh my parameters?
regards,
Mani
