BME688 BSEC OUTPUT: datasheet and integration guide
Hi! I found some inconsistencies between the information reported on the Datasheet of the BME688 and the Integration Guide about the BSEC Output. In table 20 of the datasheet, it is mentioned that there is an output of the BSEC library which is called "Sensor compensated gas resistance". However, this output is not listed in the output of the BSEC in the integration guide.  Does anyone know which information is correct?
Hi matteo,
After our internal check, we are working on a solution to improve this output and it will be made available as a standard one in the next BSEC release.
