BME688 Bsec2 Arduino Configuration
I'm using the bme688 sensor with Bsec2.4 and the Arduino platform. My code follows the example https://github.com/boschsensortec/Bosch-BSEC2-Library/blob/master/examples/generic_examples/basic/basic.ino.
I only use these virtual sensors, no need for gas index, estimations etc.
BSEC_OUTPUT_STATIC_IAQ,
BSEC_OUTPUT_RAW_TEMPERATURE,
BSEC_OUTPUT_RAW_HUMIDITY,
BSEC_OUTPUT_SENSOR_HEAT_COMPENSATED_TEMPERATURE,
BSEC_OUTPUT_SENSOR_HEAT_COMPENSATED_HUMIDITY,
BSEC_OUTPUT_RAW_PRESSURE.
Do I have to explicitly set some configuration (e.g. bme688_sel_33v_3s_4d) or is it only necessary for gas estimation ? My bme688 is powered by 3.3V and sample rate LP.  If I set it to bme688_sel_33v_3s_4d, will it make any difference ?
Thank you
