BME688 Dev Kit
I plan to use the BME688 Dev Kit and I have downloaded the Dev-Kit Software based on the official PDF from the following link:
https://www.bosch-sensortec.com/software-tools/double-opt-in-forms/bme688-devkit-software-2-1-5-form.html
However, I noticed that the downloaded package does not include a .bmeconfig file, which I would need to place on the SD card of the Dev Kit.
Shouldn’t this file be provided with the software package?
Also, I would like to confirm the following:
If I connect the Dev Kit and run the flash.bat file, will it automatically start operating in a default configuration (e.g., “coffee” detection)? And is it true that I can switch between different gas profiles using the onboard button?
Thank you in advance!
Best regards,
Maria
