I'm working with a Nucleo-G070RB microcontroller and uses the example code out ouf the library 2.0. I could read the read the ID and the initializaition, configuration and the update of the Subscription works fine. I don't forget the bsec_init.
In the function run(), the function bme68c_get_data is called and only in the first Call I get Data. But this data are absolutly wrong. In each of the next Calls, there is no change. N_filds is 0, so the following loop to proceed the data will not work.
Do you have any idea?
