Hello Bosch-Community,
I'm using the BME860 with an STM32 board via I2C. Reading temperature and pressure seems to work fine, as its values seem to make sense.
But neither humidity nor gas_resistance or humidity change. Humidity also is the wrong number, since 100 % relative humidity is a little bit over the tops.
I'm using the code, which is pretty similair to the one in the application note.
float volatile temperature = 0;
float volatile pressure = 0;
float volatile humidity = 0;
float gas_resistance = 0;
struct bme680_dev gas_sensor;
gas_sensor.dev_id = BME680_I2C_ADDR_PRIMARY;
gas_sensor.intf = BME680_I2C_INTF;
gas_sensor.read = bus_read;
gas_sensor.write = bus_write;
gas_sensor.delay_ms = HAL_Delay;
///* amb_temp can be set to 25 prior to configuring the gas sensor
//* or by performing a few temperature readings without operating the gas sensor.
gas_sensor.amb_temp = 25;
int8_t volatile rslt = BME680_OK;
bme680_init(&gas_sensor);
struct bme680_field_data data;
uint8_t set_required_settings;
/* Set the temperature, pressure and humidity settings */
gas_sensor.tph_sett.os_hum = BME680_OS_2X;//BME680_OS_2X;
gas_sensor.tph_sett.os_pres = BME680_OS_4X;//BME680_OS_4X;
gas_sensor.tph_sett.os_temp = BME680_OS_4X;//BME680_OS_4X;
gas_sensor.tph_sett.filter = BME680_FILTER_SIZE_3;//BME680_FILTER_SIZE_3;
/* Set the remaining gas sensor settings and link the heating profile */
gas_sensor.gas_sett.run_gas = BME680_ENABLE_GAS_MEAS;
/* Create a ramp heat waveform in 3 steps */
gas_sensor.gas_sett.heatr_temp = 320; /* degree Celsius */
gas_sensor.gas_sett.heatr_dur = 120; /* milliseconds */
/* Select the power mode */
/* Must be set before writing the sensor configuration */
gas_sensor.power_mode = BME680_FORCED_MODE; //BME680_SLEEP_MODE;//
/* Set the required sensor settings needed */
set_required_settings = BME680_OST_SEL | BME680_OSP_SEL | BME680_OSH_SEL | BME680_FILTER_SEL
| BME680_GAS_SENSOR_SEL;
/* Set the desired sensor configuration */
rslt = bme680_set_sensor_settings(set_required_settings,&gas_sensor);
/* Set the power mode */
rslt = bme680_set_sensor_mode(&gas_sensor);
while(1)
if (bme680_ticker > 500)
bme680_ticker = 0;
HAL_GPIO_TogglePin(LED_0_GPIO_Port, LED_0_Pin);
rslt = bme680_get_sensor_data(&data, &gas_sensor);
if(data.status & BME680_GASM_VALID_MSK){
temperature = data.temperature;
humidity = data.humidity;
pressure = data.pressure;
VOC = data.gas_resistance/1000; //Gasresistance in kohm
gas_sensor.amb_temp = temperature;
if (gas_sensor.power_mode == BME680_FORCED_MODE) {
As I was also checking my logic analyzer, but I have no idea why it cannot find any values according to the humidity or gas_resistance.
(One while loop, he retries multiple times)
I'm thankful for any help!
Sincerely Crackl1ng
