BMI I2C: Shuttle board connections and write/read functions
Hi Bosch sesnrtec community
I am using BMI160 IMU (shuttle board) as motion sesnor in my application. The MCU is MSP432P401R.
1- What is the proper wiring configuration for the shuttle board for I2C protocol?
2- I have written the code for I2C read/write functions like below:
/************BMI160 I2C*********/
UCB1CTLW0 |= UCSWRST; // **Initialize USCI state machine**
P6SEL0 |= BIT4 + BIT5;
P6SEL1 &= ~(BIT4 + BIT5); // | P6.3: UCB1SCLK| P6.4: UCB1SIMO | P6.5: UCB1SOMI (Refer to the datasheet, page: 159).
UCB1CTLW0 |= UCCKPH + UCMST + UCMSB + UCSYNC + UCSSEL_2 + UCMODE_3; // 3-pin, 8-bit, SPI master
UCB1BR0 = 12; // fSCL = SMCLK/12 = ~250kHz
UCB1BR1 = 0;
UCB1I2CSA = BMI160_I2C_ADDR; // Set slave address
UCB1CTLW0 &= ~UCSWRST; // **Initialize USCI state machine**
int8_t user_i2c_read(uint8_t dev_id, uint8_t reg_addr, uint8_t *reg_data, uint16_t len)
int8_t rslt = 0; /* Return 0 for Success, non-zero for failure */
* The parameter dev_id can be used as a variable to store the I2C address of the device
UCB1CTLW0 |= UCTR + UCTXSTT; // I2C TX, start condition
UCB1TXBUF = reg_addr; // Write reg_addr byte
UCB1CTLW0 |= UCTXSTP; // I2C stop condition.
UCB1I2CSA |= BMI160_I2C_ADDR; // Set slave address
UCB1CTLW0 &=~UCA10; //10BIT ADDRESS
UCB1CTLW0 &=~UCTR;//CLEAR TRANSMIT MODE
UCB1CTLW0 |= UCTXSTT; // I2C RX, start condition
int i=0;
for (i=0;i<len;i++)
reg_data[i]=UCB1RXBUF;
return rslt;
int8_t user_i2c_write(uint8_t dev_id, uint8_t reg_addr, uint8_t *reg_data, uint16_t len)
int i=0;
for (i=0;i<len;i++)
UCB1TXBUF=reg_data[i];
return rslt;
 Is it the right statement for them?
Thanks
Saber
Best reply by SaberKazemi1992
And also, one more question:
- What is the difference between VDD and VDDIO? Both goes to 3.3V pin of the MCU?
Thanks
Saber
