I have written this basic driver for BMI088 for ESP32 with ESP-IDF in which I am able to read registers from the sensor.
#include "bmi088.h"
#include <stdio.h>
#include <stdint.h>
#include <math.h>
#include "esp_timer.h"
#include "freertos/FreeRTOS.h"
#include "freertos/task.h"
#include "esp_log.h"
#include "driver/i2c.h"
#define I2C_MASTER_SCL_IO 22 /*!< GPIO number used for I2C master clock */
#define I2C_MASTER_SDA_IO 21 /*!< GPIO number used for I2C master data */
#define I2C_MASTER_NUM 0 /*!< I2C master i2c port number, the number of i2c peripheral interfaces available will depend on the chip */
#define I2C_MASTER_FREQ_HZ 400000 /*!< I2C master clock frequency */
#define I2C_MASTER_TX_BUF_DISABLE 0 /*!< I2C master doesn't need buffer */
#define I2C_MASTER_RX_BUF_DISABLE 0 /*!< I2C master doesn't need buffer */
#define I2C_MASTER_TIMEOUT_MS 1000
#define BM1088_ACCEL_ADDRESS 0x18 /*!< Slave address of the BM1088_acceleromter sensor SD01 pull to GND */
#define BM1088_GYRO_ADDRESS 0x68 /*!< Slave address of the BM1088 gyroscope sensor SD02 pull to GND*/
int16_t ret = 0;
/*! Earth's gravity in m/s^2 */
#define GRAVITY_EARTH (9.80665f)
static const char *TAG = "BM1088 Module";
* @brief Memory locations to store BM1088 accel and gyro Sensors data
uint8_t accel_x[2] = {0};
uint8_t accel_y[2] = {0};
uint8_t accel_z[2] = {0};
uint8_t gyro_x[2] = {0};
uint8_t gyro_y[2] = {0};
uint8_t gyro_z[2] = {0};
* @brief Convertion of BM1088 accel and gyro Sensors data into signed integer
float accel_x_int16 = 0;
float accel_y_int16 = 0;
float accel_z_int16 = 0;
float gyro_x_int16 = 0;
float gyro_y_int16 = 0;
float gyro_z_int16 = 0;
* @brief Convertion of BM1088 accel and gyro Sensors signed integer into acceleration
float accel_x_in_mg = 0;
float accel_y_in_mg = 0;
float accel_z_in_mg = 0;
* @brief calculate BM1088 data in signed form from LSB into Degree per second
float gyro_x_in_degree = 0;
float gyro_y_in_degree = 0;
float gyro_z_in_degree = 0;
* @brief Initialize angles
double yaw = 0.0;
double pitch = 0.0;
double roll = 0.0;
* @brief Initialize previous angles
double prev_yaw = 0.0;
double prev_pitch = 0.0;
double prev_roll = 0.0;
* @brief Initialize the previous timestamp
int64_t previous_timestamp = 0;
/* Initialize other variables */
double pitch_acc = 0.0;
double roll_acc = 0.0;
double gyro_x_rad = 0.0;
double gyro_y_rad = 0.0;
double gyro_z_rad = 0.0;
* @brief BM1088 IMU Register Addresses
typedef enum
ACC_CHIP_ID = 0X00,
ACC_ERR_REG = 0X02,
ACC_STATUS = 0X03,
ACC_X_LSB = 0X12,
ACC_X_MSB = 0X13,
ACC_Y_LSB = 0X14,
ACC_Y_MSB = 0X15,
ACC_Z_LSB = 0X16,
ACC_Z_MSB = 0X17,
ACC_CONF = 0X40,
ACC_RANGE = 0X41,
ACC_SELF_TEST = 0X6D,
ACC_PWR_CONF = 0X7C,
ACC_PWR_CTRL = 0X7D,
ACC_SOFT_REST = 0X7E,
GYRO_CHIP_ID = 0X00,
GYRO_X_LSB = 0X02,
GYRO_X_MSB = 0X03,
GYRO_Y_LSB = 0X04,
GYRO_Y_MSB = 0X05,
GYRO_Z_LSB = 0X06,
GYRO_Z_MSB = 0X07,
GYRO_RANGE = 0X0F,
GYRO_BANDWIDTH = 0X10,
GYRO_LPM1 = 0X11,
GYRO_SOFT_REST = 0X14,
GYRO_SELF_TEST = 0X3C,
}mpu_register_address;
void BMI088_IMU::IMU_INIT(){
uint8_t data[2];
ESP_ERROR_CHECK(i2c_master_init());
ESP_LOGI(TAG, "I2C initialized successfully");
/* Read the BM1088 GYRO_CHIP_ID REGISTER, on power up the register should have the value 0x0F */
ESP_ERROR_CHECK(bm1088_gyro_read(GYRO_CHIP_ID, data, 1));
ESP_LOGI(TAG, "GYRO_CHIP_ID_REGISTER_VALUE = %X", data[0]);
/* Read the BM1088 ACC_PWR_CTRL REGISTER to check power on reset */
uint8_t check_por[2];
ESP_ERROR_CHECK(bm1088_accel_read(ACC_PWR_CTRL, check_por, 1));
vTaskDelay(1/ portTICK_PERIOD_MS);
/* Enable accel module by writing 0x04 to power control register */
uint8_t acc_pwr_ctr = 0x04;
acc_pwr_ctr |= check_por[0];
ESP_ERROR_CHECK(bm1088_accel_write_byte(ACC_PWR_CTRL, acc_pwr_ctr));
vTaskDelay(50/ portTICK_PERIOD_MS);
if (check_por[0] == acc_pwr_ctr)
ESP_LOGI(TAG, "Accelerometer configured successfully");
else ESP_LOGI(TAG, "Accelerometer not configured ");
* @brief Read a sequence of bytes from a BM1088 accel sensor registers
esp_err_t BMI088_IMU::bm1088_accel_read(uint8_t reg_addr, uint8_t *data, size_t len){
for (size_t i = 0; i < len; i++) {
ret = i2c_master_write_read_device(i2c_port_t(I2C_MASTER_NUM), BM1088_ACCEL_ADDRESS, (®_addr + i), 1,
(data + i), 1, I2C_MASTER_TIMEOUT_MS / portTICK_PERIOD_MS );
return ret;
* @brief Read a sequence of bytes from a BM1088 gyro sensor registers
esp_err_t BMI088_IMU::bm1088_gyro_read(uint8_t reg_addr, uint8_t *data, size_t len){
ret = i2c_master_write_read_device(i2c_port_t(I2C_MASTER_NUM), BM1088_GYRO_ADDRESS, (®_addr + i), 1,
return ret;
* @brief Write a byte to a BM1088 accel sensor register
esp_err_t BMI088_IMU::bm1088_accel_write_byte(uint8_t reg_addr, uint8_t data){
uint8_t write_buf[2] = {reg_addr, data};
ret = i2c_master_write_to_device(i2c_port_t(I2C_MASTER_NUM), BM1088_ACCEL_ADDRESS, write_buf, sizeof(write_buf),
I2C_MASTER_TIMEOUT_MS / portTICK_PERIOD_MS);
return ret;
* @brief Write a byte to a BM1088 gyro sensor register
esp_err_t BMI088_IMU::bm1088_gyro_write_byte(uint8_t reg_addr, uint8_t data){
ret = i2c_master_write_to_device(i2c_port_t(I2C_MASTER_NUM), BM1088_GYRO_ADDRESS, write_buf, sizeof(write_buf),
return ret;
* @brief i2c master initialization
esp_err_t BMI088_IMU::i2c_master_init(void){
int i2c_master_port = I2C_MASTER_NUM;
i2c_config_t conf;
conf.mode = I2C_MODE_MASTER;
conf.sda_io_num = I2C_MASTER_SDA_IO;
conf.scl_io_num = I2C_MASTER_SCL_IO;
conf.sda_pullup_en = GPIO_PULLUP_ENABLE;
conf.scl_pullup_en = GPIO_PULLUP_ENABLE;
conf.master.clk_speed = I2C_MASTER_FREQ_HZ;
conf.clk_flags = 0;
i2c_param_config(i2c_port_t(i2c_master_port), &conf);
return i2c_driver_install(i2c_port_t(i2c_master_port), conf.mode, I2C_MASTER_RX_BUF_DISABLE, I2C_MASTER_TX_BUF_DISABLE, 0);
* @brief This function converts lsb to meter per second squared for 16 bit accelerometer at
* range 2G, 4G, 8G or 16G.
float BMI088_IMU::lsb_to_mps2(int16_t val, int8_t g_range, uint8_t bit_width)
double power = 2;
float half_scale = (float)((pow((double)power, (double)bit_width) / 2.0f));
return (GRAVITY_EARTH * val * g_range) / half_scale;
* @brief This function converts lsb to degree per second for 16 bit gyro at
* range 125, 250, 500, 1000 or 2000dps.
float BMI088_IMU::lsb_to_dps(int16_t val, float dps, uint8_t bit_width)
double power = 2;
return (dps / (half_scale)) * (val);
* @brief This function reads raw accel_x LSB data and converts to degree per second
double BMI088_IMU::accel_read_rawX(){
uint8_t lsb, msb;
uint16_t msblsb;
ESP_ERROR_CHECK(bm1088_accel_read(ACC_X_LSB, accel_x, 2));
lsb = accel_x[0];
msb = accel_x[1];
msblsb = (msb << 😎 | lsb;
float x_original_int = ((int16_t) msblsb); /* Data in X axis */
float x = lsb_to_mps2(x_original_int, 24, 16);
return x;
* @brief This function reads raw accel_y LSB data and converts to degree per second
double BMI088_IMU::accel_read_rawY(){
uint8_t lsb, msb;
uint16_t msblsb;
ESP_ERROR_CHECK(bm1088_accel_read(ACC_Y_LSB, accel_y, 2));
lsb = accel_y[0];
msb = accel_y[1];
float y_original_int = ((int16_t) msblsb); /* Data in Y axis */
float y = lsb_to_mps2(y_original_int, 24, 16);
return y;
* @brief This function reads raw accel_z LSB data and converts to degree per second
double BMI088_IMU::accel_read_rawZ(){
uint8_t lsb, msb;
uint16_t msblsb;
ESP_ERROR_CHECK(bm1088_accel_read(ACC_Z_LSB, accel_z, 2));
lsb = accel_z[0];
msb = accel_z[1];
float z_original_int = ((int16_t) msblsb); /* Data in Z axis */
float z = lsb_to_mps2(z_original_int, 24, 16);
return z;
* @brief This function reads raw gyro_x LSB data and converts to degree per second
double BMI088_IMU::gyro_read_rawX(){
uint8_t lsb, msb;
uint16_t msblsb;
ESP_ERROR_CHECK(bm1088_gyro_read(GYRO_X_LSB, gyro_x, 2));
lsb = gyro_x[0];
msb = gyro_x[1];
float x = lsb_to_dps(x_original_int, (float)250, 16);
return x;
* @brief This function reads raw gyro_y LSB data and converts to degree per second
double BMI088_IMU::gyro_read_rawY(){
uint8_t lsb, msb;
uint16_t msblsb;
ESP_ERROR_CHECK(bm1088_gyro_read(GYRO_Y_LSB, gyro_y, 2));
lsb = gyro_y[0];
msb = gyro_y[1];
float y = lsb_to_dps(y_original_int, (float)250, 16);
return y;
* @brief This function reads raw gyro_z LSB data and converts to degree per second
double BMI088_IMU::gyro_read_rawZ(){
uint8_t lsb, msb;
uint16_t msblsb;
ESP_ERROR_CHECK(bm1088_gyro_read(GYRO_Z_LSB, gyro_z, 2));
lsb = gyro_z[0];
msb = gyro_z[1];
float z = lsb_to_dps(z_original_int, (float)250, 16);
return z;
double BMI088_IMU::angle_read_pitch(){
double x_Buff = gyro_read_rawX();
double y_Buff = gyro_read_rawY();
double z_Buff = gyro_read_rawZ();
double pitch = atan2((- x_Buff) , sqrt(y_Buff * y_Buff + z_Buff * z_Buff)) * 57.3;
return pitch;
double BMI088_IMU::angle_read_roll(){
double roll = atan2(y_Buff , z_Buff) * 57.3;
return roll;
double BMI088_IMU::angle_read_yaw(){
return 0;
Output:
I (332) app_start: Starting scheduler on CPU0
I (337) app_start: Starting scheduler on CPU1
I (337) main_task: Started on CPU0
I (347) main_task: Calling app_main()
I (347) BM1088 Module: I2C initialized successfully
I (347) BM1088 Module: GYRO_CHIP_ID_REGISTER_VALUE = F
I (407) BM1088 Module: Accelerometer configured successfully
I (407) BM1088 Module: accel_read_rawX = 1.824382
I (407) BM1088 Module: accel_read_rawY = -228.284729
I (407) BM1088 Module: accel_read_rawZ = -229.283112
I (617) BM1088 Module: accel_read_rawX = 1.723825
I (617) BM1088 Module: accel_read_rawY = -228.291916
I (617) BM1088 Module: accel_read_rawZ = -229.168182
I (817) BM1088 Module: accel_read_rawX = 1.766921
I (817) BM1088 Module: accel_read_rawY = -228.356567
I (817) BM1088 Module: accel_read_rawZ = -229.161026
I (1017) BM1088 Module: accel_read_rawX = 0.682347
I (1017) BM1088 Module: accel_read_rawY = -229.003006
I (1017) BM1088 Module: accel_read_rawZ = -229.448318
I (1217) BM1088 Module: accel_read_rawX = 0.624887
I (1217) BM1088 Module: accel_read_rawY = -228.722870
I (1217) BM1088 Module: accel_read_rawZ = -229.017365
I (1417) BM1088 Module: accel_read_rawX = 1.795651
I (1417) BM1088 Module: accel_read_rawY = -228.291916
I (1417) BM1088 Module: accel_read_rawZ = -229.225662
I (1617) BM1088 Module: accel_read_rawX = 0.215478
I (1617) BM1088 Module: accel_read_rawY = -229.139465
I (1617) BM1088 Module: accel_read_rawZ = -228.378113
I (1817) BM1088 Module: accel_read_rawX = 1.292869
I (1817) BM1088 Module: accel_read_rawY = -228.090790
I (1817) BM1088 Module: accel_read_rawZ = -228.234467
However, the output data I get does not make sense. What am I doing wrong?
BMI088 data not making any sense
