I'm using BMI160 IMU with STM32 microcontroller. I have wrote everything, from wrappers for implementing API to sensor fusion algorithms to process raw IMU data.
But for precise operation, I need to get new sensor data at a constant rate. Since I shouldn't skip any new sensor readings, my read will be equal to sensors ODR rate. Which is 1600 Hz.
My current Accel and Gyro settings are below:
sensor.accel_cfg.odr = BMI160_ACCEL_ODR_1600HZ;
sensor.accel_cfg.range = BMI160_ACCEL_RANGE_4G;
/* Select the power mode of accelerometer sensor */
sensor.accel_cfg.power = BMI160_ACCEL_NORMAL_MODE;
sensor.accel_cfg.bw = BMI160_ACCEL_BW_NORMAL_AVG4;
sensor.gyro_cfg.odr = BMI160_GYRO_ODR_1600HZ;
sensor.gyro_cfg.range = BMI160_GYRO_RANGE_500_DPS;
/* Select the power mode of Gyroscope sensor */
sensor.gyro_cfg.power = BMI160_GYRO_NORMAL_MODE;
sensor.gyro_cfg.bw = BMI160_GYRO_BW_NORMAL_MODE;
And my current interrupt settings are:
/* Select the Interrupt channel/pin */
int_config.int_channel = BMI160_INT_CHANNEL_1;// Interrupt channel/pin 1
/* Select the Interrupt type */
int_config.int_type = BMI160_ACC_GYRO_DATA_RDY_INT;// Choosing Any motion interrupt
/* Select the interrupt channel/pin settings */
int_config.int_pin_settg.output_en = BMI160_ENABLE;// Enabling interrupt pins to act as output pin
int_config.int_pin_settg.output_mode = BMI160_DISABLE;// Choosing push-pull mode for interrupt pin
int_config.int_pin_settg.output_type = BMI160_DISABLE;// Choosing active low output
int_config.int_pin_settg.edge_ctrl = BMI160_ENABLE;// Choosing edge triggered output
int_config.int_pin_settg.input_en = BMI160_DISABLE;// Disabling interrupt pin to act as input
int_config.int_pin_settg.latch_dur = BMI160_LATCH_DUR_NONE;// non-latched output
/* Set the Any-motion interrupt */
rslt = bmi160_set_int_config(&int_config, &sensor); /* sensor is an instance of the structure bmi160_dev */
So, what type of interrupt routine should I implement?
Thank you for your answers.
