BMI160 gyro power configure problem
So I've gotten the BMI160 chip so successfully read out its accelerometer data with no problem, but when I set the power mode for the gyroscope I get no outputs and there are no errors in the error register.
Without configuring the gyro_cfg.power to BMI160_GYRO_NORMAL_MODE, I read that the PMU register has the acceleromoter in normal mode, the Status register reads accelerometer data is ready and NVM is ready as well and I can get accelerations data happily all day long.
When I configure the gyro_cfg.power the PMU Register reads 0, all suspended, and only the NVM is ready in the Status register. Still no errors. What's going on here? What am I missing that's causing the problem?
#define SPI_BUFFER_SIZE 20
#define SPI_INSTANCE  0                                             /**< SPI instance index. */
static const nrf_drv_spi_t spi = NRF_DRV_SPI_INSTANCE(SPI_INSTANCE);/**< SPI instance. */
static uint8_t spi_tx_buf[SPI_BUFFER_SIZE];                         /**< TX buffer. */
static uint8_t spi_rx_buf[SPI_BUFFER_SIZE];                         /**< RX buffer. */
bool volatile spi_xfer_done = false;
void user_delay_ms(uint32_t period) {
  nrf_delay_ms(period);
//function is called when spi transfer is complete
void spi_event_handler(nrf_drv_spi_evt_t const *p_event, void *p_context)
    //setting flag to true unblocks
    spi_xfer_done = true;
    // DPRINTF("Received: 0x%x, 0x%x, 0x%x, 0x%x, 0x%x, 0x%x, 0x%x, 0x%x, 0x%x, 0x%x, 0x%x, 0x%x, 0x%x, 0x%x, 0x%x, 0x%x, 0x%x, 0x%x, 0x%x, 0x%x\n",
    //     spi_rx_buf[0], spi_rx_buf[1], spi_rx_buf[2], spi_rx_buf[3], spi_rx_buf[4],
    //     spi_rx_buf[5], spi_rx_buf[6], spi_rx_buf[7], spi_rx_buf[8], spi_rx_buf[9],
    //     spi_rx_buf[10], spi_rx_buf[11], spi_rx_buf[12], spi_rx_buf[13], spi_rx_buf[14],
    //     spi_rx_buf[15], spi_rx_buf[16], spi_rx_buf[17], spi_rx_buf[18], spi_rx_buf[19]
//send spi command and waits for return - signaled by spi_xfer_done being true
int8_t spi_read(uint8_t dev_id, uint8_t reg_addr, uint8_t *reg_data, uint16_t length){
    ret_code_t ret ;
    reg_addr = reg_addr | 0x80;
    memset(spi_rx_buf, 0, SPI_BUFFER_SIZE);
    uint8_t * read_temp = spi_rx_buf;
    ret = nrf_drv_spi_transfer(&spi, &reg_addr, 1, read_temp, length + 1 ) ;
    while (!spi_xfer_done)
        __WFE();
    memcpy((void*)reg_data, (void*)(read_temp+1), length);
    // DPRINTF("RSLT: %d\n", ret);
    nrf_delay_ms(1);
    return (int8_t)ret;
//send a spi command and does not listen or wait for a return
int8_t spi_write(uint8_t dev_id, uint8_t reg_addr, uint8_t *reg_data, uint16_t length){
    ret_code_t ret;
    // uint8_t write_temp[ length + 1 ] ;
    spi_tx_buf[0] = reg_addr  & 0x7F;
    memcpy((void*)(spi_tx_buf+1), (void*)(reg_data), length);
    ret = nrf_drv_spi_transfer(&spi, spi_tx_buf, length + 1, NULL, 0 ) ;
        __WFE();
    return (int8_t)ret;
void imu_init(void)
    //initialize spi on nRF
    nrf_drv_spi_config_t spi_config = NRF_DRV_SPI_DEFAULT_CONFIG;
    spi_config.ss_pin = PIN_SS;
    spi_config.miso_pin = PIN_MISO;
    spi_config.mosi_pin = PIN_MOSI;
    spi_config.sck_pin = PIN_SCLK;
    spi_config.frequency = NRF_DRV_SPI_FREQ_1M;
    spi_config.mode = NRF_DRV_SPI_MODE_0;
    APP_ERROR_CHECK(nrf_drv_spi_init(&spi, &spi_config, spi_event_handler, NULL));
    //initialize BMI160 sensor
    struct bmi160_dev sensor;
    /* You may assign a chip select identifier to be handled later */
    sensor.id = 0;
    sensor.interface = BMI160_SPI_INTF;
    sensor.read = spi_read;
    sensor.write = spi_write;
    sensor.delay_ms = user_delay_ms;
    int8_t rslt = BMI160_OK;
    rslt = bmi160_init(&sensor);
    if(rslt != 0) {
        DPRINTF("Error on Sensor SPI\n");
    } else {
        DPRINTF("IMU SPI Enabled\n");
    /* After the above function call, accel_cfg and gyro_cfg parameters in the device
    structure are set with default values, found in the datasheet of the sensor */
    //foc
    uint8_t reg_addr = 0x69;
    uint8_t data = 0b11111111;
    // rslt = bmi160_set_regs(reg_addr, &data, 1, &sensor);
    // nrf_delay_ms(300); //page 45 says foc needs 250ms to configure
    // bmi160_get_regs(reg_addr, &data, 1, &sensor);
    // DPRINTF("FOC: %d\n", rslt);
    // DPRINTF("FOC register: %d\n", data);
    // reg_addr = 0x7E;
    // data = 0x03;
    sensor.accel_cfg.odr = BMI160_ACCEL_ODR_100HZ;
    sensor.accel_cfg.range = BMI160_ACCEL_RANGE_2G;
    sensor.accel_cfg.bw = BMI160_ACCEL_BW_NORMAL_AVG4;
    /* Select the power mode of accelerometer sensor */
    sensor.accel_cfg.power = BMI160_ACCEL_NORMAL_MODE;
    sensor.gyro_cfg.odr = BMI160_GYRO_ODR_200HZ;
    sensor.gyro_cfg.range = BMI160_GYRO_RANGE_250_DPS;
    sensor.gyro_cfg.bw = BMI160_GYRO_BW_NORMAL_MODE;
    /* Select the power mode of Gyroscope sensor */
    // sensor.gyro_cfg.power = BMI160_GYRO_NORMAL_MODE;
    /* Set the sensor configuration */
    rslt = bmi160_set_sens_conf(&sensor);
    if(rslt != 0) {
        DPRINTF("Error Configuring Sensor: %d\n", rslt);
    } else {
        DPRINTF("IMU Initialized\n");
    reg_addr = 0x03;
    DPRINTF("Power register: %d\n", data);
    reg_addr = 0x00;
    DPRINTF("Chip ID register: %d\n", data);
    reg_addr = 0x1B;
    DPRINTF("Status register: %d\n", data);
    //read initial gyro, accel and time data from imu
    struct bmi160_sensor_data accel;
    struct bmi160_sensor_data gyro;
    while(1) {
        bmi160_get_sensor_data((BMI160_ACCEL_SEL | BMI160_GYRO_SEL), &accel, &gyro, &sensor);
        DPRINTF("Accel: %d %d %d\t\t", accel.x, accel.y, accel.z);
        DPRINTF("Gyro: %d %d %d\n", gyro.x, gyro.y, gyro.z);
        nrf_delay_ms(1000);
