I currently have the no motion interrupt working fine as long as the duration is set to around 10 seconds or below, if i set the duration any higher than this there seems to be some sort of offset being applied causing a duration setting of 60 seconds to trigger at around 6 miniutes. So really im just abit confused about the maths used for the duration setting, I had a read of the data sheet and found the stuff relating to the slow/no motion duration delay equations however i couldnt really make much sense of it in all honesty.
My IMU is currently set up like:
ODR: 25HZ
Range: 16G
BW: NORMAL_AVG4
power mode: Normal
I would greatly appreciate any help to aid my understanding of the maths involved/issue if there is one, surrounding this.
Thank you in advance!
