I have attached a BMI160 to a Raspberry PI4, SPI0 like in this schematic:
I wanted to use it with Linux IIO bmi160 driver (-> had to compile a custom RPI4 Linux kernel with this driver included because unfortunately the standard kernel has no bmi160 IIO driver). I have added a device tree overlay with this content:
/* add bmi160 spi device with CS=1*/
fragment@1 {
target = <&spi0>;
__overlay__ {
status = "okay";
#address-cells = <1>;
#size-cells = <0>;
bmi160@1 {
compatible = "bosch,bmi160";
reg = <1>;
spi-max-frequency = <1000000>;
Now the driver gets loaded at Linux startup, but it never finds the BMI160. The driver prints out:
[ 9.978638] bmi160_spi spi0.1: supply vdd not found, using dummy regulator
[ 9.978827] bmi160_spi spi0.1: supply vddio not found, using dummy regulator
[ 9.978913] bmi160_spi spi0.1: mounting matrix not found: using identity...
[ 9.980262] bmi160_spi spi0.1: Wrong chip id, got 0 expected d1
I also checked with the Oscilloscope and never saw a signal on MISO :(. What the driver in its chip init sequence does is this (see https://elixir.bootlin.com/linux/v6.1.69/source/drivers/iio/imu/bmi160/bmi160_core.c#L719 )
1. SOFT RESET
2. Wait 1ms
3. Read register 0x7f (for switching to SPI mode)
4. Read CHIP ID
When reading the BMI160 data sheet, I wondered if this is correct, because already sending the SOFT RESET probably requires a switch to SPI mode, right? But also modifying the driver with an additional Read register 0x7f as step 0 did not change anything.
At this point I suspected there must probably be an electrical problem with my setup. But then I tried accessing the device not with the Linux IIO BMI160 driver, but with plain python3 spidev code - and the initial test code could read the CHIP ID 0xd1!
import spidev
spi = spidev.SpiDev()
spi.open(0,1)
spi.max_speed_hz = 1000000
# init SPI mode
ret = spi.xfer([0xff, 0x00])
# soft reset
ret = spi.xfer([0x7e, 0xb6])
# read id
ret = spi.xfer([0x80, 0x00])
print(f'chip id: {hex(ret[1])}')On the Oscilloscope I did not see any difference in terms of signal polarity/phase - the shape of the signal looks the same. Only this time the MISO response signal of the chip ID was there. One difference of the Python code compared with the IIO driver was the 1ms delay of the driver before the Read of the CHIP ID.
Now, the "funny" thing is: If I add this 1ms delay into the python code, I can *never* read the correct chip ID - it is always zero like the IIO driver reads it. That means, the BMI160 does not respond with the MISO signal, if I use a delay of 1ms after the SOFT RESET.
I am quite confused now - is there any explanation for this behavior? How long does the SOFT RESET take? How should an ideal initialization sequence look like?
Any support is appreciated.
Regards
Jörg
