we are using linux driver with following bmi270_config_file:
const uint8_t bmi270_config_file[] = {
0xc8, 0x2e, 0x00, 0x2e, 0x80, 0x2e, 0x1a, 0x00, 0xc8, 0x2e, 0x00, 0x2e, 0xc8, 0x2e, 0x00, 0x2e, 0xc8, 0x2e, 0x00,
0x2e, 0xc8, 0x2e, 0x00, 0x2e, 0xc8, 0x2e, 0x00, 0x2e, 0xc8, 0x2e, 0x00, 0x2e, 0x90, 0x32, 0x21, 0x2e, 0x59, 0xf5,
0x10, 0x30, 0x21, 0x2e, 0x6a, 0xf5, 0x1a, 0x24, 0x22, 0x00, 0x80, 0x2e, 0x3b, 0x00, 0xc8, 0x2e, 0x44, 0x47, 0x22,
0x00, 0x37, 0x00, 0xa4, 0x00, 0xff, 0x0f, 0xd1, 0x00, 0x07, 0xad, 0x80, 0x2e, 0x00, 0xc1, 0x80, 0x2e, 0x00, 0xc1,
0x80, 0x2e, 0x00, 0xc1, 0x80, 0x2e, 0x00, 0xc1, 0x80, 0x2e, 0x00, 0xc1, 0x80, 0x2e, 0x00, 0xc1, 0x80, 0x2e, 0x00,
0xc1, 0x80, 0x2e, 0x00, 0xc1, 0x80, 0x2e, 0x00, 0xc1, 0x80, 0x2e, 0x00, 0xc1, 0x80, 0x2e, 0x00, 0xc1, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x11, 0x24, 0xfc, 0xf5, 0x80, 0x30, 0x40, 0x42, 0x50, 0x50, 0x00, 0x30, 0x12, 0x24, 0xeb,
0x00, 0x03, 0x30, 0x00, 0x2e, 0xc1, 0x86, 0x5a, 0x0e, 0xfb, 0x2f, 0x21, 0x2e, 0xfc, 0xf5, 0x13, 0x24, 0x63, 0xf5,
0xe0, 0x3c, 0x48, 0x00, 0x22, 0x30, 0xf7, 0x80, 0xc2, 0x42, 0xe1, 0x7f, 0x3a, 0x25, 0xfc, 0x86, 0xf0, 0x7f, 0x41,
0x33, 0x98, 0x2e, 0xc2, 0xc4, 0xd6, 0x6f, 0xf1, 0x30, 0xf1, 0x08, 0xc4, 0x6f, 0x11, 0x24, 0xff, 0x03, 0x12, 0x24,
0x00, 0xfc, 0x61, 0x09, 0xa2, 0x08, 0x36, 0xbe, 0x2a, 0xb9, 0x13, 0x24, 0x38, 0x00, 0x64, 0xbb, 0xd1, 0xbe, 0x94,
0x0a, 0x71, 0x08, 0xd5, 0x42, 0x21, 0xbd, 0x91, 0xbc, 0xd2, 0x42, 0xc1, 0x42, 0x00, 0xb2, 0xfe, 0x82, 0x05, 0x2f,
0x50, 0x30, 0x21, 0x2e, 0x21, 0xf2, 0x00, 0x2e, 0x00, 0x2e, 0xd0, 0x2e, 0xf0, 0x6f, 0x02, 0x30, 0x02, 0x42, 0x20,
0x26, 0xe0, 0x6f, 0x02, 0x31, 0x03, 0x40, 0x9a, 0x0a, 0x02, 0x42, 0xf0, 0x37, 0x05, 0x2e, 0x5e, 0xf7, 0x10, 0x08,
0x12, 0x24, 0x1e, 0xf2, 0x80, 0x42, 0x83, 0x84, 0xf1, 0x7f, 0x0a, 0x25, 0x13, 0x30, 0x83, 0x42, 0x3b, 0x82, 0xf0,
0x6f, 0x00, 0x2e, 0x00, 0x2e, 0xd0, 0x2e, 0x12, 0x40, 0x52, 0x42, 0x00, 0x2e, 0x12, 0x40, 0x52, 0x42, 0x3e, 0x84,
0x00, 0x40, 0x40, 0x42, 0x7e, 0x82, 0xe1, 0x7f, 0xf2, 0x7f, 0x98, 0x2e, 0x6a, 0xd6, 0x21, 0x30, 0x23, 0x2e, 0x61,
0xf5, 0xeb, 0x2c, 0xe1, 0x6f};
With this gyro self-test is failing:
# cat self_test
[E]3<BS_LOG><gyro_self_test_show><1478>Gyro self test fail -23
If this is replaced with https://github.com/BoschSensortec/BMI270-Sensor-API/blob/master/bmi270.c, self test passes:
# cat self_test
Gyro Self test successful
We have machines in field with this bmi270_config_file and we have some issues with gyro (sometimes wrong values are reported). Can you please check if this issue can be due to this config ? We are using it because we don't need any guestures, wrist detection, etc... and driver init is much faster with this config
