BMI270 gyroscope always zero immediately after initialisation
The first few gyroscope samples immediately after initialisation are always zero.  The corresponding accelerometer samples are of expected values.  Both the gyroscope and accelerometer are configured for the same ODR.  Data is read each time the data-ready interrupt is asserted.
This behaviour suggests that the gyroscope and accelerometer are not synchronised.  Please can someone clarify what is going on.
The number of consecutive gyroscope samples equal to zero immediately after initialisation is constant for each ODR as summarised in the table below.  These values are not affected by gyr.filter_perf or gyr.noise_perf.
ODR (same for gyro and accel)Number of gyro zero samplesCalculated period (ms)1002202006304001743800384816008251
Here is the initialisation code for reference:
    // Initialise device
    if (bmi270_init(&bmi270) != BMI2_OK) {
        initialisationFailed = true;
        return;
    // Perform soft reset
    bmi2_soft_reset(&bmi270);
    bmi2_set_adv_power_save(BMI2_DISABLE, &bmi270);
    // Enable accelerometer and gyroscope
    const uint8_t sensorList[] = {BMI2_ACCEL, BMI2_GYRO};
    bmi2_sensor_enable(sensorList, 2, &bmi270);
    // Configure accelerometer
    struct bmi2_sens_config accelerometerConfig = {
        .type = BMI2_ACCEL,
        .cfg.acc.odr = BMI2_ACC_ODR_400HZ,
        .cfg.acc.bwp = BMI2_ACC_NORMAL_AVG4,
        .cfg.acc.filter_perf = 1,
        .cfg.acc.range = BMI2_ACC_RANGE_16G,
    bmi2_set_sensor_config(&accelerometerConfig, 1, &bmi270);
    // Configure gyroscope
    struct bmi2_sens_config gyroscopeConfig = {
        .type = BMI2_GYRO,
        .cfg.gyr.odr = BMI2_GYR_ODR_400HZ,
        .cfg.gyr.bwp = BMI2_GYR_NORMAL_MODE,
        .cfg.gyr.filter_perf = 1,
        .cfg.gyr.ois_range = BMI2_GYR_OIS_2000,
        .cfg.gyr.range = BMI2_GYR_RANGE_2000,
        .cfg.gyr.noise_perf = 1,
    bmi2_set_sensor_config(&gyroscopeConfig, 1, &bmi270);
    // Configure data ready interrupt on INT1 pin
    struct bmi2_int_pin_config intPinConfig = {
        .pin_type = BMI2_INT1,
        .int_latch = BMI2_INT_NON_LATCH,
        .pin_cfg[0].lvl = BMI2_INT_ACTIVE_HIGH,
        .pin_cfg[0].od = BMI2_INT_PUSH_PULL,
        .pin_cfg[0].output_en = BMI2_INT_OUTPUT_ENABLE,
        .pin_cfg[0].input_en = BMI2_INT_INPUT_DISABLE,
    bmi2_set_int_pin_config(&intPinConfig, &bmi270);
    bmi2_map_data_int(BMI2_DRDY_INT, BMI2_INT1, &bmi270);
Best reply by shellywang
This is an expected behavior.
After sensor initialization, both accelerometer and gyroscope are in suspend mode by default.
The startup time it takes the accelerometer to start from suspend mode to normal mode is different from the time it takes the gyroscope. The gyroscope is slower than the accelerometer.
In other words, they are not synchronized at the beginning. But once the gyroscope starts up, they will be synchronized.
