BMI270 initialization problem with nRF52840
Hello everyone, as i read in other topic on this forum i am also struggling to use BMI270 sensor, especially for initialization process.
I'm using nRF52840 SoC and i connected it to the IMU by using twi/i2c intarface.
Here i attach my code for initialization:
//INIT FUNCTION FOR BMI270
bool BMI270_init(void)
  bool init_succ=true;
  //following datasheet
  if(!BMI270_verify_product_id())
   init_succ=false;
  if(!BMI270_register_write(0x7C,0x00))
    init_succ=false;
  nrf_delay_us(800);
  if(!BMI270_register_write(0x59,0x00))
    init_succ=false;
// load configuration file from github repo
  while(BMI270_conf_file_init())
 if(!BMI270_register_write(0x59,0x01)){
    init_succ=false;// it seems that main problem is in this step
  return init_succ;
 and these are the code for writing and reading registers:
bool BMI270_register_write(uint8_t register_address , uint8_t value)
  ret_code_t err_code;
  uint8_t tx_buff[BMI2_ADDRESS_LEN+1];
  tx_buff[0]=register_address;
  tx_buff[1]=value;
  m_xfer_done=false;
  //transimt data
  err_code=nrf_drv_twi_tx(&m_twi,BMI2_I2C_PRIM_ADDR,tx_buff,BMI2_ADDRESS_LEN+1,false);
  while(m_xfer_done==false)
  if(err_code != NRF_SUCCESS)
    return false;
  return true;
bool BMI270_register_read(uint8_t register_address,uint8_t *destination,uint8_t number_of_bytes)
  //flag for check receive
  m_xfer_done=false;
  //writing address we want to read
  err_code=nrf_drv_twi_tx(&m_twi,BMI2_I2C_PRIM_ADDR,&register_address,1,true);
  while(m_xfer_done==false){}
      return false;
  m_xfer_done=false;
  //read data
  err_code=nrf_drv_twi_rx(&m_twi,BMI2_I2C_PRIM_ADDR,destination,number_of_bytes);
      return false;
   return true;
For burst write the config file i wrote an external function that rewrite on i2c bus the byte from config file:
bool BMI270_conf_file_init(void)
   uint8_t buff[2];
   int a;
   for(a=0;a<(sizeof(bmi270_context_config_file)-1);a++)
     buff[0]=0x5E;
     buff[1]=bmi270_context_config_file[a];
     err_code=nrf_drv_twi_tx(&m_twi,BMI2_I2C_PRIM_ADDR,buff,2,true);
            return false;
     buff[0]=0x5E;
     buff[1]=bmi270_context_config_file[sizeof(bmi270_context_config_file)-1];
     err_code=nrf_drv_twi_tx(&m_twi,BMI2_I2C_PRIM_ADDR,buff,2,false);
            return false;
   return true;
 The fact is that as i commented in the first code the initialization works until the last step where the function give me a false, also by bypassing that return false, it seems that reading the 0x5E register at the end of initialization the value does not correspond to the last byte of bmi270_context_config_file.
I know that are present on the github the API's for this sensor but i didn't understand how i can replace my writing and reading function to implement it.
Is there any way to overcome initialization burst write? And if it's not possible, how can i solve it?
PS: these are the declaration of the type fucntion used to write and read using twi of the SoC:
//reading function
ret_code_t nrf_drv_twi_rx	(	nrf_drv_twi_t const * 	p_instance,
uint8_t 	address,
uint8_t * 	p_data,
uint8_t 	length
//writing function
ret_code_t nrf_drv_twi_tx	(	nrf_drv_twi_t const * 	p_instance,
uint8_t 	address,
uint8_t const * 	p_data,
uint8_t 	length,
bool 	no_stop
