BMI270 INT1 & INT2 no interrupt on hardware pin
I'm using the BMI270 shuttle board. The sensor is set up correctly and I can read data from the accelerometer and gyroscope. I have tested all the code provided on GitHub. All codes are working fine. I received all interrupts on the terminal. But there is no interrupt sense on INT1 & INT2 pin. I have map interrupt provided in the source code. I have copied the source code as it is.
Please guide me to resolve the issue.
Thanks in adavanced.
Regards,
Suhas
