BMI270 Wrist Wear Wakeup Angle Definitions
I really don't understand the wrist wake-up angles as specified in the datasheet:
 .min_angle_focus    - Minimum expected change in attitude angle in a 1
    //                       second period when moving within focus position.
    //                       Value is 2048 * cos(angle) (default: 1448 = 45 deg)
    //                       Range is 1024 to 1774 (60 to 30 deg)
    // .min_angle_nonfocus - Minimum expected change in attitude angle in a 1
    //                       second period when moving from non-focus position
    //                       to the focus position.
    //                       Value is 2048 * cos(angle) (default: 1774 = 30 deg)
    //                       Range is 1448 to 1856 (45 to 25 deg)
    // .max_tilt_lr        - Maximum tilt angle to the right that defines the
    //                       focus position.
    //                       Value is 2048 * sin(angle) (default: 1024 = 30 deg)
    //                       Range is 700 to 1024 (20 to 30 deg)
    // .max_tilt_ll        - Maximum tilt angle to the left that defines the
    //                       focus position.
    //                       Value is 2048 * sin(angle) (default: 700 = 20 deg)
    // .max_tilt_pd        - Maximum tilt angle to the front that defines the
    //                       focus position.
    //                       Value is 2048 * sin(angle) (default: 179 = 5 deg)
    //                       Range is 0 to 179 (0 to 5 deg)
    // .max_tilt_pu        - Maximum tilt angle to the back that defines the
    //                       focus position.
    //                       Value is 2048 * sin(angle) (default: 1925 = 70 deg)
    //                       Range is 1774 to 1978 (60 to 75 deg)
In particular, .max_tilt_pd and .max_tilt_pu.  I have tried different values, but they seems to have no effect.  In essence, I am trying to adjust the orientation that the sensor has to be in for the wrist wear wake-up to work.  I don't think it would kill Bosch to put a picture in their datasheet - but whatever.
1
