BMO055 land pattern recommendation
Is there a document describing the recommended land pattern for the BMO055 part?  All I can find is a reference in the Handling, soldering & mounting instructions that says the width should be the same as the pin and the length should be +.1mm on either side of the pin.  I can't find the dimension of the pins themselves.
