Hello everyone,
I have a question about BMP280, pressure sensor. I want to use both interfaces of the sensor (I2C & SPI). But I am not sure that the sensor has not synchronise communicate when I try to use both of them. Because datasheet has 'power on reset should be done in order to switch interface you will use'.And power on reset is only executed when both VDD and VDDIO are established. So,
Can bmp280's communication interface be changed (i.e. SPI-->I2C) unless power-on-reset is not done?
