BMP390 configuration error when setting OSR
Hi all,
I am using a BMP390 and measuring works fine in standard configuration. I can switch to normal mode and fetch proper measurements.
However, as soon as I try to set the OSR register the BMP390 goes into an "configuration error" state and switches to sleep mode and then i am unable to activate normal mode again. A soft reset cmd will restore the defaults and fixes this. However OSR is also reset then.
The datasheet didnt really clarify to me what is happening exactly. I tried different OSR configurations, I dont see what could be wrong with any of those. Are there any configurations that are not allowed or have to be set together?
Best regards
Mark
