I need to configure the BMP390 to generate an interrupt when the DRDY condition is met.
I have tired various configuration of settings.int_settings and cannot ever see the interrupt pin changing state on an oscilloscope. It does change state when I manually toggle the pin between Vdd and Gnd.
I have attached my code for reference. Which appears to run and I see valid Pressure and Temperature reading echo on my serial output.
Please can someone help with this issue?.
