[BMP581]: Problem reading the pressure via I2C
I'm using a BMP581 Shuttle Board 3.0 and I'm having problems reading the pressure via I2C. I read six registers starting at the 0x1D address (TEMP_DATA_XLSB). The temperature data seems to be correct. Nevertheless, the pressure registers are always set to the default value 0x7F. The CS and SDO pins are connected to VDDIO and VDDIO is connected to VDD (3.3V). Moreover, the values I write in ODR_CONFIG and DRIVE_CONFIG registers are not saved and I cannot write to OSR_CONFIG register.
Which could be the problem?
