Hi, I'm having an issue with Shuttle board 3.1 which has bmv080 sensor.
I'm using Visual Studio Code with PlatformIO.
My esp32 is full name - DOIT wifi model-eps32-32 n4 fccid:2bb7-esp32-32x ism 2.4g 802.11b/g/n
I tired of using SPI and I2C. And getting error and cant manage to make it work.
I select project as: bmv080-sdk-v11-1-0\api_examples\xtensa_esp32
in the xtensa_esp32 folder there is a src folder which contains combridge.c file. In combridge.c is written for SPI connection use -
#if defined(BOARD_ESP32_V2)
/* SPI GPIO Configuration */
#define PIN_NUM_MISO 21
#define PIN_NUM_MOSI 19
#define PIN_NUM_CLK 5
#define PIN_NUM_CS 15
So i wire up like that the shuttle board 3.1 to my ESP32.
And getting error -
Initializing IRQ
Opening BMV080 sensor unit failed with BMV080 status 107
Executing the sensor APIs failed with bmv080 status 107
And same issue with the i2c method , getting error the 106 or 107
Tried to use different eps32 board - esp32 dowdq6 v3 422023 ug00mak008
Still getting same issue:
Initializing IRQ
Or is it only works with adafruit_feather_esp32_v2 ? Because i replaced that with - esp32doit-devkit-v1
So my main question is:
Does someone have a connection information how to correctly wire shuttle board 3.1(application board 3.1) to esp32 ? SPI or I2C ways please π π π π
No matter how i tried to connect, always getting error 107 or 106, for both ways spi or i2c.
Kind Regards
