BMX055 with BSX Lite Bug
I have spent the last week trying to figure out why the BSX Lite library (Cortex M0+ version from the BMF055 evaluation board shark demo) would give bad orientation data on my custom BMX055 board whenever I fed the gyro data into the library.
In order to save everyone else having this problem some time, here is what I found: In bmf055.h, the gyro is initialized as
/* BMG settings for running BSXLite: Range = 500dps, BW = 64Hz*/
bmg160_set_range_reg(0x02);
bmg160_set_bw(0x06);
This is wrong! Apparently that version of BSX lite requires 250dps, so all raw values are too low by a factor of 2. If I change this to
/* BMG settings for running BSXLite: Range = 250dps, BW = 64Hz*/
bmg160_set_range_reg(0x03); // fixed range
it works. Another alternative if one wants to keep the larger gyro range is to manually scale the raw values instead:
/* Read and process gyro data */
bmg160_get_data_XYZ(&bmf055_gyr_data);
/* Convert the timer tick to micro seconds */
timestamp_dataxyz.gyro.time_stamp = local_timestamp * 1000;
timestamp_dataxyz.gyro.data.x = bmf055_gyr_data.datax*2; // scale everything
timestamp_dataxyz.gyro.data.y = bmf055_gyr_data.datay*2;
timestamp_dataxyz.gyro.data.z = bmf055_gyr_data.dataz*2;
With these modifications is works very well. I'm a bit lost though why they are required. I find it hard to believe that such a bug has made it into the evaluation board, as it pretty much breaks the sensor fusion. So it might be something else, but I have not idea what could cause an incorrect reduction by a factor of 2.
