To whom it may concern,
I use the bno055 sensor and i would like to calibrate it.
To do this, I use a STM32 as brain, as well as the provided bno055.c driver and I communicate in I2C between them.
And I don't know how to do to calibrate the sensor.I read the documentation of the sensor on the calibration, I watch the video on the calibration of the sensor that bosch has done. But in the video you use a software
At this time, I made this code :
u8 sys_stat = 0, accel_stat = 0, gyro_stat = 0, mag_stat = 0;
bno055_reset_sensor(); //function which applies a low signal to the nReset pin for more than 20ns
bno055_init(&bno055);
bno055_set_power_mode(BNO055_POWER_MODE_NORMAL);
bno055_set_operation_mode(BNO055_OPERATION_MODE_NDOF);
BNO055_delay_msek(7); //switching time
do{
if(bno055_get_all_calib_stat(&sys_stat,
&accel_stat,
&gyro_stat,
&mag_stat) != BNO055_SUCCESS) break;
BNO055_delay_msek(5000);
}while(sys_stat != 3 ||
accel_stat != 3 ||
gyro_stat != 3 ||
mag_stat != 3);But nothing happens when the sensor does not move (for gyro) or even if it make 8 (for mag)
Thank you in advance
Regards
