BNO055 Heading Drifts
We appear to be getting a small number of BNO055 parts (with firmware 0x0311) come through that will ultimately see the heading drift over an extended period of time. The application requires a stationary sensor to not exceed 20 degrees in any of heading, roll or pitch over 12 hours. No issues with roll or pitch. Only heading. We have been ensuring that sensors are calibrated prior to running our tests on these few problem sensors and that they have passed self-tests. The sensors are configured for NDOF operation mode (0x0C).
Is there more we need to be doing? Should we be monitoring the calibration status of each of system, mag, gyr and acc? Are there other register entries we should be monitoring? Is it possible to determine whether sensors are faulty at all? - this would be most useful prior to deploying them out into the field, something that does not require testing over an extended period of time (more than 10 minutes).
Thank you in advance.
