we are using the BNO055 in one of our applications. We combine the IMU with a PIC 16bit microcontroller on the same board.The MCU communicates with the IMU over I2C and we use the c library provided by Bosch. Overall the IMU works fine. Only the following problem occurs: When freshly programming the MCU, the BNO does not respond. Resetting the BNO over the RST line does not help. Only after unplugging the power of the board and therefore restarting the MCU and BNO, the BNO works as expected. After the intial power off/on the BNO works fine. Only right after programming and entering the application code, the BNO is stuck. Sadly this will cause a problem for us, when deploying an Over the air MCU firmware update, when the product is out in the field. Do you have an idea of why this issue occurs or maybe hint me in the direction of a solution?
Kind regards
