Hello all,
I have an Adafruit BNO055 breakout board and the temperature fluctuates pretty wildly between the actual temperature and something completely wrong - in the range of -99 to -103 degrees C, with the typical wrong value of -102 degrees C. So, while printing values at 1 Hz, it will display the error value (-102 C) then occasionally display the correct temperature of 26 degrees C.
Is there an issue with the temperature sensor on this chip? Any way to reset it?
Thanks!
