BSEC 1.4.7.4 compilation error on ESP32 1.0.3-rc1
Hi
I have followed the instruction. My platform.txt
These can be overridden in platform.local.txt
compiler.c.extra_flags=
compiler.c.elf.extra_flags=
#compiler.c.elf.extra_flags=-v
compiler.cpp.extra_flags=
compiler.S.extra_flags=
compiler.ar.extra_flags=
compiler.elf2hex.extra_flags=
compiler.libraries.ldflags=
recipe.c.combine.pattern="{compiler.path}{compiler.c.elf.cmd}" {build.exception_flags} -Wl,-Map "-Wl,{build.path}/{build.project_name}.map" {compiler.c.elf.flags} {compiler.c.elf.extra_flags} -o "{build.path}/{build.project_name}.elf" -Wl,--start-group {object_files} "{archive_file_path}" {compiler.c.elf.libs} {compiler.libraries.ldflags} -Wl,--end-group "-L{build.path}"
but Arduino IDE gives an error xtensa-esp32-elf-gcc: error: {build.exception_flags}: No such file or directory
1.4.7.2 with arduino-builder.exe from bosch works perfectly but now i can't find anywhere these arduino-builder.exe, its obsolete?
