I'm working with a STM32G070 MCU and the library 2.061 The heater_profil always stays the same, altough I have already change it and restart the whole system. The sensor get the old information from the function bsec_sensor_control.
I took the heater profile from the github parallel example, but in my case the measured temperature is to high. There is a 5 Celcius degree difference between the raw data from parallel mode to the raw data from the forced mode. The forced mode is much nearer to my comparison sensor. Even the compensated temperature has a difference about 2-3 degree to the forced mode.
Do you have any ideas?
Best regards
