Hello!
Based on my findings in this forum. If I want to calibrate the BHI260AP sensors, I need to do that with the Development Desktop 2.0 tool. Following this tutorial: https://www.youtube.com/watch?v=Bw0WuAyGsnY
When opening the Development Desktop 2.0 application, it requests a connection board. I expected that I can use the Nicla as connection board, but it seems not to work since I can not connect it "No response from the board. Please select correct port".
Am I wrong with this, or is there a way to create a calibration routine and use the BHY2 library to update the calibration?
Since I most likely need to have the board in an environment where I can not just flash the sensor, I would like to calibrate it based on the surroundings. I saw the "bhy2_set_calibration_profile" method in the BHY2-Sensor-API/bhy2.c file, but could not see it referenced somewhere else then here BHI260AB-calibration.
Thank You
