Data loss with Application Board 2.0 when using Bluetooth
My question concerns the Application Board 2.0 Bluetooth with a BMX055 shuttle board. I tried out some measurements with only the accelerometer on (gyroscope and magnetometer are in suspended mode). When the application board is connected to the laptop via the USB port, all readings are recorded correctly in the Development Desktop software. However, when the Bluetooth connection between the application board and the laptop is used (instead of the USB connection), the software records only about 10% of the readings, the remaining 90% seem to be lost. This is the case even with a small distance between the laptop and the application board. I am wondering which settings need to be made so that all measured values ​​can be transmitted via the Bluetooth connection. Unfortunately, a reduction of the measurement resolution is not an option as I need high resolution. Thank you in advance.
