Discussion on dynamic calibration problems of lsm303agrtr magnetometer and impact of accelerometer interference
Problem background
I'm developing a lsm303agrtr based on (integrated accelerometer + magnetometer)based on Understanding the LSM303AGRTR Sensor Features
  • Calibration process: Complete hard magnetic calibration (through the ellipse fitting algorithm) (complete hard magnetic calibration (through the ellipse fitting algorithm)
  • Parameter settings: magnetometer odr = 30Hz±50µT; accelerometer odr = 100Hz, range ±4g
  • Temperature compensation: Enable the built-in temperature sensor, sampling interval 10 seconds
Specific problem description
1. The magnetometer heading angle drifts during high-speed movement
When the drone performs pitch/rolling action (angular velocity > 200°/s), the magnetometer heading angle error accumulates to ±25° within 5 seconds (the error is < ±3° in static environment)
Try solutions:
Adjust the sensor fusion algorithm (complementary filtering + extended Kalman filtering)
Reduce magnetometer ODR to 10Hz to reduce motion interference
Turn off the accelerometer power supply in magnetometer data update gap (POWER_DOWN mode via CTRL1_REG)
doubt:
Section 7.3 of the data sheet mentions "dynamic accuracy is not defined", does this mean that the sensor is not suitable for high-speed motion scenarios?
Are there hidden registers (such as undisclosed HPF filtering configurations) that improve dynamic response?
2. Effect of accelerometer vibration on magnetometer Z-axis
When the accelerometer detects high-frequency vibration (such as motor vibration, frequency > 80Hz), step noise of ±15µT appears in the Z-axis axis of the magnetometer, resulting in the failure of the heading algorithm that is highly dependent on Z-axis data.
Comparative test:
When using an independent BMM150 magnetometer + LSM6DSO accelerometer combination, the Z-axis noise is <±3µT under the same vibration environment.
After disabling the LSM303AGRTR accelerometer, the Z-axis noise of the magnetometer returns to normal level
doubt:
Is this related to mechanically coupled interference in the sensor package? Does "Cross-Axis Sensitivity" in Section 9.2 of the Datasheet contain such situations?
Are there any recommended hardware layout improvements (such as power isolation or mechanical decoupling)?
