Error compiling BSEC on ESP8266 with Arduino IDE
Hi everyone,
I would kindly need support for compiling a script for the ESP8266 controller with Arduino IDE.
I have a BME680 sensor connected to a NodeMCU 8266 controller and some time ago I already created a working script to read the air quality index (Arduino IDE 1.8.11 and I don't remember which version of BSEC).
Today I tried to load the same script again with Arduino IDE 1.8.12 and BSEC 1.4.7.4, but there is no way to compile it, I always find the same error. Also trying with basic example provided with BSEC library.
I read on the internet that there are problems with the IDE 1.8.12, so I tried to remove it completely (even doing folder cleaning) and to install version 1.8.9, but unfortunately without success.
I state that I have applied exactly the indications for Arduino contained in the pdf present in the BSEC package.
I replaced the arduino-builder-219.exe file, modified the platform.txt and eagle.app.v6.common.ld files as indicated and placed the libalgobsec.a files in the BSEC library folder (trying both the normal and light version).
Despite this, I find the following error:
Arduino:1.8.9 (Windows 10), Scheda:"NodeMCU 1.0 (ESP-12E Module), 80 MHz, Flash, Legacy (new can return nullptr), All SSL ciphers (most compatible), 4MB (FS:2MB OTA:~1019KB), 2, v2 Lower Memory, Disabled, None, Only Sketch, 115200"
c:/users/david/appdata/local/arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/2.5.0-4-b40a506/bin/../lib/gcc/xtensa-lx106-elf/4.8.2/../../../../xtensa-lx106-elf/bin/ld.exe: libraries\bsec\bsec.cpp.o: in function `Bsec::i2cRead(unsigned char, unsigned char, unsigned char*, unsigned short)':
C:\Users\david\Documents\Arduino\libraries\bsec\src/bsec.cpp:442: undefined reference to `bsec_init'
c:/users/david/appdata/local/arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/2.5.0-4-b40a506/bin/../lib/gcc/xtensa-lx106-elf/4.8.2/../../../../xtensa-lx106-elf/bin/ld.exe: C:\Users\david\Documents\Arduino\libraries\bsec\src/bsec.cpp:442: undefined reference to `bsec_get_version'
c:/users/david/appdata/local/arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/2.5.0-4-b40a506/bin/../lib/gcc/xtensa-lx106-elf/4.8.2/../../../../xtensa-lx106-elf/bin/ld.exe: libraries\bsec\bsec.cpp.o: in function `Bsec::beginCommon()':
C:\Users\david\Documents\Arduino\libraries\bsec\src/bsec.cpp:448: undefined reference to `bsec_init'
c:/users/david/appdata/local/arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/2.5.0-4-b40a506/bin/../lib/gcc/xtensa-lx106-elf/4.8.2/../../../../xtensa-lx106-elf/bin/ld.exe: C:\Users\david\Documents\Arduino\libraries\bsec\src/bsec.cpp:133: undefined reference to `bsec_get_version'
c:/users/david/appdata/local/arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/2.5.0-4-b40a506/bin/../lib/gcc/xtensa-lx106-elf/4.8.2/../../../../xtensa-lx106-elf/bin/ld.exe: libraries\bsec\bsec.cpp.o: in function `Bsec::begin(unsigned char, TwoWire&)':
C:\Users\david\Documents\Arduino\libraries\bsec\src/bsec.cpp:104: undefined reference to `bsec_update_subscription'
c:/users/david/appdata/local/arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/2.5.0-4-b40a506/bin/../lib/gcc/xtensa-lx106-elf/4.8.2/../../../../xtensa-lx106-elf/bin/ld.exe: libraries\bsec\bsec.cpp.o: in function `Bsec::updateSubscription(bsec_virtual_sensor_t*, unsigned char, float)':
C:\Users\david\Documents\Arduino\libraries\bsec\src/bsec.cpp:155: undefined reference to `bsec_update_subscription'
c:/users/david/appdata/local/arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/2.5.0-4-b40a506/bin/../lib/gcc/xtensa-lx106-elf/4.8.2/../../../../xtensa-lx106-elf/bin/ld.exe: libraries\bsec\bsec.cpp.o: in function `Bsec::Bsec()':
C:\Users\david\Documents\Arduino\libraries\bsec\src/bsec.cpp:70: undefined reference to `bsec_do_steps'
c:/users/david/appdata/local/arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/2.5.0-4-b40a506/bin/../lib/gcc/xtensa-lx106-elf/4.8.2/../../../../xtensa-lx106-elf/bin/ld.exe: libraries\bsec\bsec.cpp.o: in function `Bsec::readProcessData(long long, bsec_bme_settings_t)':
C:\Users\david\Documents\Arduino\libraries\bsec\src/bsec.cpp:288: undefined reference to `bsec_do_steps'
c:/users/david/appdata/local/arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/2.5.0-4-b40a506/bin/../lib/gcc/xtensa-lx106-elf/4.8.2/../../../../xtensa-lx106-elf/bin/ld.exe: libraries\bsec\bsec.cpp.o:(.text._ZN4Bsec3runEv+0x4): undefined reference to `bsec_sensor_control'
c:/users/david/appdata/local/arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/2.5.0-4-b40a506/bin/../lib/gcc/xtensa-lx106-elf/4.8.2/../../../../xtensa-lx106-elf/bin/ld.exe: libraries\bsec\bsec.cpp.o: in function `Bsec::run()':
C:\Users\david\Documents\Arduino\libraries\bsec\src/bsec.cpp:166: undefined reference to `bsec_sensor_control'
collect2.exe: error: ld returned 1 exit status
exit status 1
Could anyone kindly help me?
Thanks
Yours sincerely
David
Best reply by Davide
UPDATE: got it works! 😁
I did fresh installation of IDE 1.8.11 and everythings works fine...
