ESP32 C3 BME680 BSCE2 Error Code -2
Hey everyone i have problems getting a bme680 to run on an esp32 c3. if i try the example code of the bsec2 library i get the error bme680 error code -2 in the output of the serial monitor...i use the i2c communication via sda and scl in the arduino ide
I also tried to change:
BME68X_I2C_ADDR_LOW
to 0x77 but sadly same output. error code -2
Sample Code:
 * Copyright (C) 2021 Bosch Sensortec GmbH
 * SPDX-License-Identifier: BSD-3-Clause
/* If compiling this examples leads to an 'undefined reference error', refer to the README
 * at https://github.com/BoschSensortec/Bosch-BSEC2-Library
/* The new sensor needs to be conditioned before the example can work reliably. You may run this
 * example for 24hrs to let the sensor stabilize.
 * basic.ino sketch :
 * This is an example for illustrating the BSEC virtual outputs and
 * which has been designed to work with Adafruit ESP8266 Board
#include <bsec2.h>
/* Macros used */
#define PANIC_LED   LED_BUILTIN
#define ERROR_DUR   1000
/* Helper functions declarations */
 * @brief : This function toggles the led when a fault was detected
void errLeds(void);
 * @brief : This function checks the BSEC status, prints the respective error code. Halts in case of error
 * @param[in] bsec  : Bsec2 class object
void checkBsecStatus(Bsec2 bsec);
 * @brief : This function is called by the BSEC library when a new output is available
 * @param[in] input     : BME68X sensor data before processing
 * @param[in] outputs   : Processed BSEC BSEC output data
 * @param[in] bsec      : Instance of BSEC2 calling the callback
void newDataCallback(const bme68xData data, const bsecOutputs outputs, Bsec2 bsec);
/* Create an object of the class Bsec2 */
Bsec2 envSensor;
/* Entry point for the example */
void setup(void)
    /* Desired subscription list of BSEC2 outputs */
    bsecSensor sensorList[] = {
            BSEC_OUTPUT_IAQ,
            BSEC_OUTPUT_RAW_TEMPERATURE,
            BSEC_OUTPUT_RAW_PRESSURE,
            BSEC_OUTPUT_RAW_HUMIDITY,
            BSEC_OUTPUT_RAW_GAS,
            BSEC_OUTPUT_STABILIZATION_STATUS,
            BSEC_OUTPUT_RUN_IN_STATUS
    /* Initialize the communication interfaces */
    Serial.begin(115200);
    Wire.begin();
    pinMode(PANIC_LED, OUTPUT);
    /* Valid for boards with USB-COM. Wait until the port is open */
    while(!Serial) delay(10);
    /* Initialize the library and interfaces */
    if (!envSensor.begin(BME68X_I2C_ADDR_LOW, Wire))
        checkBsecStatus(envSensor);
    /* Subsribe to the desired BSEC2 outputs */
    if (!envSensor.updateSubscription(sensorList, ARRAY_LEN(sensorList), BSEC_SAMPLE_RATE_ULP))
    /* Whenever new data is available call the newDataCallback function */
    envSensor.attachCallback(newDataCallback);
    Serial.println("BSEC library version " + \
            String(envSensor.version.major) + "." \
            + String(envSensor.version.minor) + "." \
            + String(envSensor.version.major_bugfix) + "." \
            + String(envSensor.version.minor_bugfix));
/* Function that is looped forever */
void loop(void)
    /* Call the run function often so that the library can
     * check if it is time to read new data from the sensor
     * and process it.
    if (!envSensor.run())
void errLeds(void)
    while(1)
        digitalWrite(PANIC_LED, HIGH);
        delay(ERROR_DUR);
        digitalWrite(PANIC_LED, LOW);
        delay(ERROR_DUR);
    if (!outputs.nOutputs)
        return;
    Serial.println("BSEC outputs:\n\ttimestamp = " + String((int) (outputs.output[0].time_stamp / INT64_C(1000000))));
    for (uint8_t i = 0; i < outputs.nOutputs; i++)
        const bsecData output  = outputs.output[i];
        switch (output.sensor_id)
            case BSEC_OUTPUT_IAQ:
                Serial.println("\tiaq = " + String(output.signal));
                Serial.println("\tiaq accuracy = " + String((int) output.accuracy));
                break;
            case BSEC_OUTPUT_RAW_TEMPERATURE:
                Serial.println("\ttemperature = " + String(output.signal));
                break;
            case BSEC_OUTPUT_RAW_PRESSURE:
                Serial.println("\tpressure = " + String(output.signal));
                break;
            case BSEC_OUTPUT_RAW_HUMIDITY:
                Serial.println("\thumidity = " + String(output.signal));
                break;
            case BSEC_OUTPUT_RAW_GAS:
                Serial.println("\tgas resistance = " + String(output.signal));
                break;
            case BSEC_OUTPUT_STABILIZATION_STATUS:
                Serial.println("\tstabilization status = " + String(output.signal));
                break;
            case BSEC_OUTPUT_RUN_IN_STATUS:
                Serial.println("\trun in status = " + String(output.signal));
                break;
            default:
                break;
    if (bsec.status < BSEC_OK)
        Serial.println("BSEC error code : " + String(bsec.status));
        errLeds(); /* Halt in case of failure */
    else if (bsec.status > BSEC_OK)
        Serial.println("BSEC warning code : " + String(bsec.status));
    if (bsec.sensor.status < BME68X_OK)
        Serial.println("BME68X error code : " + String(bsec.sensor.status));
    else if (bsec.sensor.status > BME68X_OK)
        Serial.println("BME68X warning code : " + String(bsec.sensor.status));
