Hello there,
I am currently working with the ESP32 WROOM DevKitC v4 and got issues with compiling File>Examples>Bsec software library>Basic from the examples.
I got the following setup:
Arduino IDE 2.0.0-beta.10 (as well tested with version 1.8.18)
MC: ESP32 WROOM DevKitC v4
BSEC-Library installed via Library-Manager as well as zip installation from current master branch (https://github.com/BoschSensortec/BSEC-Arduino-library)
The plattform.txt file was changed according to the manual on Github.
Following Error occurs: (see long_log in attachment)
Spoiler
C:\Users\jonas\AppData\Local\Temp\arduino-sketch-1637E99D06118CEA2DDFA0CCD3C525D3\libraries\BSEC-Arduino-library-master\BSEC-Arduino-library-master.a(bsec.cpp.o):(.literal._ZN4Bsec11beginCommonEv+0x4): undefined reference to `bsec_init'C:\Users\jonas\AppData\Local\Temp\arduino-sketch-1637E99D06118CEA2DDFA0CCD3C525D3\libraries\BSEC-Arduino-library-master\BSEC-Arduino-library-master.a(bsec.cpp.o):(.literal._ZN4Bsec11beginCommonEv+0x8): undefined reference to `bsec_get_version'
C:\Users\jonas\AppData\Local\Temp\arduino-sketch-1637E99D06118CEA2DDFA0CCD3C525D3\libraries\BSEC-Arduino-library-master\BSEC-Arduino-library-master.a(bsec.cpp.o):(.literal._ZN4Bsec18updateSubscriptionEP21bsec_virtual_sensor_thf+0x0): undefined reference to `bsec_update_subscription'
C:\Users\jonas\AppData\Local\Temp\arduino-sketch-1637E99D06118CEA2DDFA0CCD3C525D3\libraries\BSEC-Arduino-library-master\BSEC-Arduino-library-master.a(bsec.cpp.o):(.literal._ZN4Bsec8setStateEPh+0x10): undefined reference to `bsec_set_state'
C:\Users\jonas\AppData\Local\Temp\arduino-sketch-1637E99D06118CEA2DDFA0CCD3C525D3\libraries\BSEC-Arduino-library-master\BSEC-Arduino-library-master.a(bsec.cpp.o):(.literal._ZN4Bsec15readProcessDataEx19bsec_bme_settings_t+0x14): undefined reference to `bsec_do_steps'
C:\Users\jonas\AppData\Local\Temp\arduino-sketch-1637E99D06118CEA2DDFA0CCD3C525D3\libraries\BSEC-Arduino-library-master\BSEC-Arduino-library-master.a(bsec.cpp.o):(.literal._ZN4Bsec3runEx+0x0): undefined reference to `bsec_sensor_control'
C:\Users\jonas\AppData\Local\Temp\arduino-sketch-1637E99D06118CEA2DDFA0CCD3C525D3\libraries\BSEC-Arduino-library-master\BSEC-Arduino-library-master.a(bsec.cpp.o):(.literal._ZN4Bsec3runEx+0x4): undefined reference to `bsec_get_state'
C:\Users\jonas\AppData\Local\Temp\arduino-sketch-1637E99D06118CEA2DDFA0CCD3C525D3\libraries\BSEC-Arduino-library-master\BSEC-Arduino-library-master.a(bsec.cpp.o): In function `Bsec::beginCommon()':
e:\Daten\Dokumente\Arduino\libraries\BSEC-Arduino-library-master\src/bsec.cpp:476: undefined reference to `bsec_init'
C:\Users\jonas\AppData\Local\Temp\arduino-sketch-1637E99D06118CEA2DDFA0CCD3C525D3\libraries\BSEC-Arduino-library-master\BSEC-Arduino-library-master.a(bsec.cpp.o): In function `Bsec::getVersion()':
e:\Daten\Dokumente\Arduino\libraries\BSEC-Arduino-library-master\src/bsec.cpp:476: undefined reference to `bsec_get_version'
C:\Users\jonas\AppData\Local\Temp\arduino-sketch-1637E99D06118CEA2DDFA0CCD3C525D3\libraries\BSEC-Arduino-library-master\BSEC-Arduino-library-master.a(bsec.cpp.o): In function `Bsec::updateSubscription(bsec_virtual_sensor_t*, unsigned char, float)':
e:\Daten\Dokumente\Arduino\libraries\BSEC-Arduino-library-master\src/bsec.cpp:476: undefined reference to `bsec_update_subscription'
C:\Users\jonas\AppData\Local\Temp\arduino-sketch-1637E99D06118CEA2DDFA0CCD3C525D3\libraries\BSEC-Arduino-library-master\BSEC-Arduino-library-master.a(bsec.cpp.o): In function `Bsec::setState(unsigned char*)':
e:\Daten\Dokumente\Arduino\libraries\BSEC-Arduino-library-master\src/bsec.cpp:476: undefined reference to `bsec_set_state'
C:\Users\jonas\AppData\Local\Temp\arduino-sketch-1637E99D06118CEA2DDFA0CCD3C525D3\libraries\BSEC-Arduino-library-master\BSEC-Arduino-library-master.a(bsec.cpp.o): In function `Bsec::readProcessData(long long, bsec_bme_settings_t)':
e:\Daten\Dokumente\Arduino\libraries\BSEC-Arduino-library-master\src/bsec.cpp:385: undefined reference to `bsec_do_steps'
C:\Users\jonas\AppData\Local\Temp\arduino-sketch-1637E99D06118CEA2DDFA0CCD3C525D3\libraries\BSEC-Arduino-library-master\BSEC-Arduino-library-master.a(bsec.cpp.o): In function `Bsec::run(long long)':
e:\Daten\Dokumente\Arduino\libraries\BSEC-Arduino-library-master\src/bsec.cpp:200: undefined reference to `bsec_init'
e:\Daten\Dokumente\Arduino\libraries\BSEC-Arduino-library-master\src/bsec.cpp:210: undefined reference to `bsec_update_subscription'
e:\Daten\Dokumente\Arduino\libraries\BSEC-Arduino-library-master\src/bsec.cpp:210: undefined reference to `bsec_sensor_control'
e:\Daten\Dokumente\Arduino\libraries\BSEC-Arduino-library-master\src/bsec.cpp:246: undefined reference to `bsec_get_state'
collect2.exe: error: ld returned 1 exit status
Using library BSEC-Arduino-library-master at version 1.6.1480 in folder: e:\Daten\Dokumente\Arduino\libraries\BSEC-Arduino-library-master
Using library Wire at version 1.0.1 in folder: C:\Users\jonas\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\libraries\Wire
Using library SPI at version 1.0 in folder: C:\Users\jonas\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\libraries\SPI
Compilation error: Error: 2 UNKNOWN: exit status 1
If you need anything, pls let me know.
Thank you in advance.
Sincerely,
Jonas
