I got a BHI260AP on a Shuttle Board 3.0 and an Application board 3.0.
I modified the quaternion.c example to read additional virtual sensors from the board (accel, accel_calib, gyro, gyro_calib, ...). I created several callback functions that push the sensor data to arrays, that I then want to write to *.csv files in the end.
However, as soon as I add >2 virtual sensors with a sampling rate of 200Hz the FIFO starts to overflow. According to this document (https://www.bosch-sensortec.com/media/boschsensortec/downloads/application_notes_1/bst-bhi260ab-an002.pdf) I should have "plenty" of FIFO space available (Figure 3 -> 240KB/2?).
If I calculate the amount of data (let's say 4 virtual sensors, 200Hz each, 3*16bit) I would arrive at 4.8KB / second. That should not exhaust the FIFO right? I tried flushing the FIFO in the main loop, but that made no difference? I also increased WORK_BUFFER_SIZE from 2048 to 8192 but that did not make a difference either.
