Gyro Zero rate offset
I am considering use of a gyro from Bosch. However, I find that the datasheets are not very detailed.
I would only need Z-axis gyro, but I would need rather good stability. I can do calibration of each unit. I assume that typical values in data sheets (most are 3 degrees/sec, some 0.5) are typical uncalibrated values. Use would be only room temperature.
What is typical/max long-term stability  for the different gyro sensors after calibration?
Hello KurtM,
Close this ticket. If you have any reply in the future, you could update it here.
